2016年9月16日に発売。モデル番号は1778,1784。 GSM かCDMAの32、128、256GBがあり、色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラックがあり。
714の回答 すべて表示
Home button tap isnt working but touch ID is
I have two iPhone 7 plus's one Was working completely fine Until I decided to test out the screen on the broken one that Is waiting for parts. So the broken one needs a new screen and a battery I replaced the battery and figured well lets test it out with my phone that's currently working so I took of the screen and attached it to the other and everything turned on and worked except the home button the touch it and the ID witch I was expecting but when I put it back on the original phone only the touch ID works and not the home touch its self I have to use the assist and also now the volume will not go up or down with the buttons it registers me trying to turn it up and down but doesn't do anything. I tried a hard reset a factory reset and I am just all out of ideas !
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
I know its been awhile Wanted to thank everyone for the help the cable was damaged I replaced the screen and everything worked again .
による
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
3回答
選択されたソリューション
As for the volume buttons. Check that the cable is plugged in and not ripped cause it runs under the battery so it is possible that it was cut. They are very fragile and thing cables.
この回答は役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
If the click function doesn't work but the Touch ID does, then that is caused by a damaged IC (Turtle IC / U10) on the home button flex. This typically happens when the flex is transferred from one screen to another. The IC is sitting on some tiny solder balls and when the flex is pried off the screen, those solder balls can crack or break.
This can be repaired but requires a micro-soldering repair.
この回答は役に立ちましたか?
スコア 4
コメント:
Yeah that's exactly what I did . I transferred the screen to another phone to see if it would turn on then when I put it back the button wouldn't work and the volume and the call speaker .
による
コメントを追加
Try to change the home button from other display and see if she’s working and try to make Rest of ur phone
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
hughes さん、ありがとうございました!
統計データを表示:
過去 24時間: 2
過去 7 日: 38
過去 30 日: 202
今までの合計 1,822
