メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
Would it be possible to replace the touch bar with normal fn keys?
I'm interested in finding out from anyone that has looked at the mbp touch bar & not touch bar internals, if it would be possible to have the chassis body machined to allow for swapping in the non touch bar keyboard?
Basically I want to restore the physical function keys from a sanely designed (non touch bar) laptop. Is there enough space? What cabling would I need to create or modify to do this?
I'm sure there will be issues with the firmware to accomplish this. I think it would be an interesting academic exercise to sniff the bus and see what we could do to work around that. At this point I'm wanting to dig up any specs, schematics, first hand knowledge or any other helpful information for this project. If it seems promising, I'm willing to take this further. Imagine how cool it would be to have a frankenmac keyboard mod kit, lol.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
5件の回答
ベストアンサー
As you can see, entirely different machines.
MacBook Pro 13インチ Function Keys Late の分解
MacBook Pro 13インチ Touch Barの分解
I don't believe this will be possible, Apple has to squeeze everything into such tiny space, therefore practically left zero space for any modifications and parts have to be custom made for each model.
MacBook Pro 13" Function Keys Late 2016の画像
ガイド
難易度:
中レベル
MacBook Pro 13" Touch Bar Late 2016の画像
ガイド
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
there is probably a board under there, which is probably heavily screwed or glued on, the oled panel itself is also glued on, macOS would probably give you an error since it wouldn't be able to detect the touch id sensor so you would probably have to reroute many cables, which might not even be possible
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Sadly no not possible ;-{
さんによる
コメントを追加
I wonder if you even need to alter the chassis. The MacBook Air keyboard might simply fit, and the connector for the real keyboard portion of the MBP may be the same.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Sorry guy just not possible.
さんによる
コメントを追加
In keyboard options there’s a checkbox to permanently make the function keys stay on the touchbar.
all it does is swap over the fn functionality so that instead of showing you the fun keys it shows you the touchbar instead.
theres no way to physically swap out the touchbar though, just the software option to get them back permanently or app specific. I customised mine so I’m happy with it, i hardily used the function keys anyway for most apps so it’s a welcome change that needs some more software tweaks I think.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
@jonpleasetalk - The OP wanted the physical Fn keys in his 15" MacBook Pro Touch Bar system. He didn't want to set the Touch Bar into Fn mode.
さんによる
I should have been clearer. I found my way here when learning about the Touch Bar and noticed there was no reference to the fact that you can have the function keys there all the time. I think it's useful to know and much easier than considering replacing a Touch Bar with regular keys, even if it was possible.
さんによる
コメントを追加
The dumb emoji bar sucks even if you have it set to show function keys all the time. It still "sleeps," so you have to hit it twice to reveal the Escape key (for example). Also, Apple's baffling ignorance of the Delete key continues... you can't even add a legit Delete key to the emoji bar, even though it's a strip of soft keys! WTF!
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I couldn't agree more! Great eye candy, useless in the real world as a replacement of the normal function keys.
If I was Apple I would have mounted it to the display assembly chin panel and left the Fn keys alone! Then it's in my normal sight line, I can reach up to get to it without needing to looking down and lastly not distracting.
さんによる
backspace (labeled as delete) does most the work. For forward deletion when editing text, you can generally use Ctrl-D, which is a traditional UNIX key combination (in readline & emacs).
さんによる
The escape key is still a regular, physical key.
さんによる
コメントを追加
回答を追加する
mike s さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 40
今までの合計 4,911
