メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
320回答 すべてを表示
Migrating Drive From A Late 2013 rMBP To A 2017 Touchbar MBP?
I'm migrating away from my Late 2013 Retina MBP to my brand new Mid 2017 Touchbar MBP
I have the old SSD drive in an external USB enclosure. The drive has two partitions – a large Mac one and a smaller Windows one
As opposed to doing the whole migration-assistant stuff, I'd like to simply clone the drive over to my new machine – copying everything, both partitions, from the old to the new
I'm wondering two things:
First, what's the simplest way to go about that? If I were to startup the new mac in recovery mode, attach the external SSD, and do a restore from it... would that achieve what I'm looking for? Is there a pathway to that?
Second, should I expect any problems to arise from the old system residing in the new machine? For instance, the old system didn't have a touchbar; would the OS (I think it's running Sierra) get confused by the new hardware?
Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Cloning usually erases the whole target drive thus loosing your repair partion and Windows partion. I’d stay with Migration Assistant.
このアンサーは役に立ちましたか?
スコア 3
7 件のコメント:
@mayer I think you misunderstand the situation. The new drive has no Windows partition yet; I'm looking to copy both the Windows partition and Mac partition from the old drive over onto the new one.
さんによる
Reread my answer and give it a try then come back.
さんによる
I agree with @mayer Cloning won't work here!!
You'll need to reconfigure the drive to match as a minimum the same partition mapping size wise. Then you'll need to use Migration Assistant to migrate the MacOS partition which I suspect has the special BootCamp partition within it. The 2nd Windows exFAT partition will only need a simple copy of your data over within Windows.
さんによる
@mayer I read your post just fine; you speak of cloning erasing the target drive thus losing my Windows partition. There is no windows partition on it to lose. Again, I think you are very thoroughly misunderstanding my situation.
But thank you for trying to help.
さんによる
@andraleia Go ahead and try it your way. You do understand that the Mac OS X puts a separate partition on the drive for repairs? Cloning is not going to work to do what you want!
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Andraleia さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 78
