メインコンテンツにスキップ
2012年3月に発売されたオリジナルiPad2の改良版モデルです。より小さくなったダイプロセッサと再デザインされた内部構造が特長です。修理にはヒート(熱)を当てて、十分注意しながらこじ開けて行く作業が必須です。
73回答 すべてを表示
IPad 2 Screen is black but the roatation is visible
My sister's IPad 2 seems to be doing a weird glitch where when she turns on her IPad, the screen has a little bit of light, indicating the the screen is on, but it's black. However, when we rotate the IPad screen, we can see the lock screen wallpaper while it's rotating but every time it rotates to black. We tried resetting and when we do so, the Apple logo is clear on the middle of the screen, as if the screen isn't even broken. We was wondering if there were any other fixes we could try.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
That's an odd problem...
I would start by doing a hard reset (home & power button for 10 secs) and then a full DFU Restore if that doesn't help. Make sure to backup your device first (if it is already trusted on iTunes, it will be easy).
Once those "software" solutions have been tried, if you still have the problem, it is a hardware issue and possibly a logic board issue. At that point, you will want to have it looked at by an experienced tech.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
kardanjo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 53
