How to install a reverse horn for Honda Amaze?
I would like to install a reverse horn that gets activated when the reverse gear is engaged.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @rakeshblitz ,
Try finding something similar to this (example only) where you are (car parts stores or electronics supply stores perhaps), as it is the simplest way to do it.
Just replace one of the car’s reversing lights with this “modified” bulb and it will beep every time you put the car into reverse gear.
このアンサーは役に立ちましたか?
Unfortunately I was not able to find it in India, even online.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 249
