メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
Repair guides and support for many cameras in the PowerShot Line.
790の回答 すべてを表示
Canon g7x markii cant no longer connect to phone
Can any one help me please? i just bought canon g7x mark ii.in the beginning i was succesfully connect my camera to phone and was able to transfer photo with no problems at all after i was done transferring images i was disconnect.after that i cant no longer connect at all after several attempts. When i try to press the wifi button it leads me to access point and the name of our wifi name appeared and then leads to "start dedicated app on target device" appeared on the screen and it just keeps on loading but nothing happen and the left side of the camera keep on blinking in green.please help coz i cant no longer think of any solution
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
8件の回答
最も参考になった回答
When it says "start dedicated app on target device" open the app you used previously on your phone. Then select the camera from the options in the app.
この回答は役に立ちましたか?
スコア 1
コメント:
Is the app you mean is the canon camera connect?
さんによる
Yes. The same app you used previously.
さんによる
コメントを追加
this one worked for me. you need to reset your camera settings.
# press menu
# press setup then 4
  1. reset all
  2. then click the wifi button
  3. set name
  4. click the mobile icon
この回答は役に立ちましたか?
スコア 1
コメント:
Thank you , work great now just need to reset all
さんによる
コメントを追加
Same issue here. Have tried resetting WiFi settings on the camera uninstalling the app and reinstalling and using both the camera access point and our WiFi and still can no longer get passed “Start dedicated app on target device.” It’s worked fine for over a year so not sure if it’s an app update causing the issue?
この回答は役に立ちましたか?
スコア 0
コメント:
My husband found the solution and not having anymore issues since then.just go to camera connect app rmthwn chiise connection guide then choose canon powershit g7x mark ll /NFC next is while the canon camera is turn off the buttom part of canon should be place close to the back of your phone so that they can connect to each other once you establish the connection the canon will turn on automatically if not succesful you have to re do it until connection establish.
さんによる
Can you explain again & in more detail pls? I have the same %#*@ problem & i’m so frustrated. I need it fixed asap.
さんによる
You have to open your canon camera connect app then choose" easy connection guide" then " canon powershot g7x mark ii/NFC.while your canon camera is turn off the buttom part of the camera needs to be place or close to the back of your phone so that the phone will able to find/establish the connection to the canon camera.if not succesful you have to repeat the procedure again until the two(phone and camera) will connect to each other.
さんによる
I did try to post some photos in here on how it looks like or to show how i did it but not possible.photos doesnt upload..ugh
さんによる
your explanation doesn't make sense. easy connection guide then it says select camera etc.??? "while your canon camera is turn off the buttom part of the camera needs to be place" ??? turn off what? while your camera is what? turned off??? does an iPhone 6s work with nfc? i literally tried almost everything! i'm so frustrated. i never had problems with it untill i tried to connect to another wifi signal.
さんによる
4件以上のコメントを表示
コメントを追加
It unfortunately didn't work for me either. I'm waiting to hear back from Canon support as I think its linked with the latest iOS update.
この回答は役に立ちましたか?
スコア 0
コメント:
try to connect to another wifi signal & then go back if it doesn't work. it worked for me cuz i have 2 wifi signals apparently lol.
さんによる
Any update on this? I also have the same problem.
さんによる
コメントを追加
Hi, I’m in really need of dire help here. My camera can’t seem to connect to my phone no matter what I do, it used to work successfully but whenever I try to send videos through my phone it converts the movie first but it keeps on disconnecting before it’s even sent — I never used to have this problem before so I don’t know why it’s being complicated now.
この回答は役に立ちましたか?
スコア 0
コメントを追加
worked for me. Use NFC connection. Just follow the instructions. Thanks!
この回答は役に立ちましたか?
スコア 0
コメントを追加
Yap..problem solved long time ago. Thanks though
この回答は役に立ちましたか?
スコア 0
コメントを追加
Thanks!!! This is the solution!!!!
You only have to reset all the wi-fi settings.
Just press menu and find this function :)
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
agnesablin さん、ありがとうございました!
統計データを表示:
過去 24時間: 9
過去 7 日: 66
過去 30 日: 261
今までの合計 9,542
