camera submerged in water will not turn on
camera got wet in sea water no power battery charging light come on when charging
Salt water will rapidly corrode and cause permanent damage in all electronic devices, do not attempt to use this unless you know it's 100% dry as water will also zap circuits.
I would suggest as this was exposed to salt water it will need to be pulled apart and cleaned as even when water evaporates salt will remain and corrosion will continue.
Sorry to say but it could be time for replacement
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 82
