Head lights work but no low beams
2002 Ford Escape. Hi beams are the only thing that work. Low beams don't. I have changed bulbs and fuses, and switch. Is there a way to find the hi beams until I can figure out what's wrong and fix it?
So either the light switch is bad or you may have a damaged wire. I would start using a volt meter to see if your getting power from the switch first then if that's okay start looking for a bad wire. Have you tested the bulbs to make sure they work. Using a jumper wire to the low beam wire to the battery will be an easy test to see the lights work
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 297
