メインコンテンツにスキップ
ニンテンドーの第四世代GameCubeコンソール式ゲームシステムです。修理は簡単で、一般的なツールで対応できます。
91回答 すべてを表示
Disk spinner gummed up, can't spin fast enough for the disk to be read
Recently bought a used Gamecube. It boots up fine and eventually gets to the menu screen displayed when there's no disk. I do have a disk in it that works fine on my old Gamecube, but it says "no disk" when I select "Game Play". If I open the lid and close it again the no disk becomes a question mark, before quickly reverting to no disk again. I can hear the disk spinning briefly before giving up when it decides that there's nothing in there. The spinner is quite noticeably stiffer than my old one, and my guess is that it just can't get up to speed. I'm not sure if its something mechanical broken or has just gotten gummed up inside, but if anyone has thoughts on how to clean/fix the optical drive spinner I would be really grateful!
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The part in question is called a spindle motor and this is a common failure for CD players as well. The only way to truly resolve this is to replace the motor with a new one. I don't recall the exact motor in these units, but a typical motor costs between $6-$10. There is a tolerance for the installation though. There is a "table" that is attached to the motor spindle. If the height is not correct, the disc won't be read either.
Hope this helps,
Dan
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Francis Woodville さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 1,892
