I am LOCKED OUT of my own laptop. How do I get in?
i HAVE a HP STREAM laptop with Intel. I am locked out. How do I get access to a backdoor so I can get back in?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You'll need a bootable windows repair drive then follow this video
https://www.youtube.com/watch?v=4aNs0VdH...
Works great
Hope this helps
このアンサーは役に立ちましたか?
You can use a start boot cd, search for OPHCRACK, it can remove your password or decrypt it.
Or you can try Hirens Boot, there is a loot of tools to remove passwords
このアンサーは役に立ちましたか?
I had a similar problem, the only way I was able to solve this was to use Lazesoft password recovery to reset the password. All you need is another computer and a USB flash drive; If the free version doesn't work try installing the free trial.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 4,935
1件のコメント
There are multiple forms of being locked out of this particular system. Are you being challenged by a BIOS based code or a Windows system credential lock out? The procedures to proceed from each situation are different.
Brian Y さんによる
