メインコンテンツにスキップ
The Motorola G5s Plus can be identified by its model number: XT1804 (varies based on country). It is an updated version of the 5th generation of Motorola’s Moto G series. Some distinguishing features of this device are its metal unibody design, improved front and rear cameras, and bigger battery.
9の回答 すべてを表示
Usb charger smells burnt after use with my phone
I bought and started using my g5s plus 12 days ago, today i notuced a soft bu,zing sound coming from my turbo power charger(included in the box) and i looked into it. While doing this i found my usb port( on the power brick) and the usb connecter( that goes in the power brick) smelt burnt.
I tried another charger thay has been used with a moto e4 before and that smells a little bit burnt too now.
Turbopower is 3 amperes
Does this have something to do with my phone or is this normal?
Should i get my phone replaced(if so is that free or is this noy covered by warrabty)?
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Also, is it stilk safe to charge my phone now?
by
コメントを追加
Android 修理キット
交換用スクリーンやバッテリーの修理キット
ショップを見る
Android 修理キット
ショップを見る
1 件の回答
選択されたソリューション
Get the phone replaced. This should be covered under warranty. It was caused probably by the fast charger
/ cable provided by your phone or the charging circuit not working properly on your phone. I would also ask for the wall charger and cable to be replaced just in case.
この回答は役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Thomas van de Weerd さん、ありがとうございました!
統計データを表示:
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 44
今までの合計 733
