メインコンテンツにスキップ
1.6または1.8GHz デュアルコアプロセッサー、 2GBまたは4GBのSDRAM, 64GBまたは128GB SSD
192回答 すべてを表示
MBA 2011 11" mainboard swap
I have a MacBook Air 11" from 2011 with 64 GB SSD and 2 GB RAM. Nice machine, I look for an 4 GB logic board swap for it.
What models are usable for that, all 11" from 2011 up to 2014 models?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
The SSD drive's interface in this model limits your choices. The newest models use a different drive and the iSight camera connection to the logic board is different as well. Basically you are locked in with the Mid 2011.
さんによる
oh, I didnt know that, thanks, Dan..
さんによる
コメントを追加
1 件の回答
最も参考になった回答
This is the only logic board IFIXIT has right now: MacBook Air 11" (Mid 2011) 1.6 GHz Logic Board There is also a 1.8 GHz board but you’ll need to look online as they are very fleeting as many people want them. Here’s the IFIXIT guide to put it in: MacBook Air 11インチ Mid 2011のロジックボードの交換
I wouldn’t spend to much on this system as before you know it it will cost more than a new system. As far as a new system… Rumor has it Apple will be introducing a newer Air system either at WWDC next week or later in the fall. If your system is working right now I would hold off to see what they do.
MacBook Air 11" (Mid 2011) 1.6 GHz Logic Boardの画像
製品
$79.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jamba さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 68
