メインコンテンツにスキップ
修理作業が必要なデバイスに対して使用する電子装置の使用方法を紹介します。
79回答 すべてを表示
Why is my mini USB port not powering?
Hi, I have a very unique question that I guarantee you will not find anywhere else on the web. I have this device. The actual socket that i plug the micro usb cable into came unglued (or unstuck) from the motherboard. I disassembled the device so that i could try and reconnect it manually to see if i could power the device with an open motherboard and i got no dice. So I have the mother board, the socket for the micro usb cable, and the micro usb cable itself. I am just wondering why i cant get any power to my device. I wish i could add photos but i cant for some reason. Please email me if you would with to assist me further.
Bguhles@hotmail.ca
Thank you very much
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The micro-usb connector is not glued on the motherboard, it is soldered on. Additionally, the traces or pads are probably damaged as well as it sounds like the connector was physically damaged.
Putting it back on manually or gluing it wont work. It has to be soldered on. That is the only way to connect it electrically speaking.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Brendan Guhle さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 127
