メインコンテンツにスキップ
2015年3月のアップデートではアップルの13インチMacBook Airは第5世代Intel Core i5またはi7プロセッサーを特徴としており、これによりわずかな性能とバッテリーライフの向上がされました。
623回答 すべてを表示
MacBook air, spilled coke on keyboard but acting normal
5 days ago i spilled a small amount of coke(soda) on my macs touchpad and keyboard. saw some seep down into the crevices of the space bar. didn’t think it was a big deal, but after a couple hours i reopened the mac and each key on the top 2 rows were typing 3 letters for every 1 press and the curser was almost impossible to move. tried to get the battery out but didn’t have the screwdriver required so i let it sit (open, upside down with fan) and after 5 days, it is acting completely normal. how should i move forward?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Consider getting the tools to open up the MacBook to inspect the logic board, connectors, ribbon cables and trackpad board for any signs of liquid damage on corrosion.
The usual hotspots to identify where the liquid went is on the black sticker layer which is part of the keyboard, you will see this once you remove the logic board / battery.
You may see some white marks on the black sheeting that covers the keyboard that is where you should look especially on the logic board as corrosion is likely to be sitting at those spots.
A good way to go about this for the meantime is to use 99% isopropyl alcohol and use a brush to remove the corrosion on the logic board. You can do this on connectors and components on the logic board, ribbon cables as well but be careful with them as they are thin cables.
Avoid brushing hard on the logic board as it is possible to dislodge capacitors by doing so.
You may miss some spots of corrosion that can only be seen under a microscope as they can be hiding near very small components or chips.
Note: Avoid plugging the laptop into a charger or turning it on for now, as there is most likely still corrosion / liquid inside your MacBook which can get worse if not cleaned properly.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Josh Lynch さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 14
今までの合計 2,879
