How does the toggle button for mute connect to the bracket
Hey y'all,
For the toggle button on the iphone 6, does it ride in the "hooks" on the bracket or just it does it just bolt up against it? I can't get it back together
If you look at the mute switch bracket, you will see a small electronic switch. The mute switch should have an indent for the switch to sit in. When putting on the mute switch, you need to ensure the switch sits over the small switch on the bracket. Also, there are 2 arms on either side of the bracket. The prongs on the sides of the mute switch sit inside the arms. With those 2 in place, when it is screwed in it should stay firmly in place.
このアンサーは役に立ちましたか?
I received a new switch. I put the switch over the electronic button. Before screwing it to the housing it moves both directions beautifully. However when I screw it down, it will click once and then nothing. It’s kinda just in the middle. It won’t go left or right
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 30
