メインコンテンツにスキップ
10 MP camera with 20x wide angle optical image stabilized zoom. Released in December 2008.
10回答 すべてを表示
Is there anyway to remove burst batteries if I can't open the door?
I had my camera in storage for a couple of years and didn't realize I left batteries in it. It seems like one or more of them leaked causing the battery door to stick shut. Is there anyway to dismantle the camera and repair it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Gently tap the battery door with the back of a screwdriver. The stuff running out of leaky batteries is very briddle, it wil probably crumble when you tap it. The batteries might be a bit swollen due to the corrosion, so the battery springs don’t push the bateries out. Could be a bit of hassle, but I think you’l manage.
Cleaning the corrosive fluid inside the camera is the bigger challenge, it might have done some damage. If not, stop it from doing so by cleaning the contacts with alcohol.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Myste Shryack さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 120
