This issue is usually caused by a physically damaged / worn charging port or the battery itself.
Charging port requires soldering so for that one you will need to take it to a repair shop that does Samsung Tablets.
For the battery it is user replaceable and fairly cheap to do. $15.
Here are link to parts and guide from iFixit:
Samsung Galaxy Tabのバッテリー交換
Samsung Galaxy Tab A 8.0 Battery
A red blinking notification LED light at the top left only when charging usually means that the device thinks that the battery temperature is too low.
This is usually a fault caused by a component like a thermistor (temperature sensor) in the charging circuit sometimes from liquid damage or damage on the charging port itself.
But I don't think that is the case as it would usually say 'Battery temperature too low. Charging paused' and the device would actually stop charging with a blinking battery icon.
Does it charge fine while it's turned off? anyway it's probably just the battery in your case.
My Cabana image picture tab 9” flickering while charging and does not switch on. I don’t no if the phone is fully charge. Android 8
Ella さんによる
