メインコンテンツにスキップ
iPad Air 第2世代のセルラーモデル用修理ガイドです。
87回答 すべてを表示
My ipad screen getting wrong.
Can anyone explain what wrong with my screen? I tend to order a new screen and replace by myself but I'm not sure what the cause is? I’ll appreciate if anyone had the same problem with me and share your experiences for a precisely diagnostic! Thanks you so much!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
I would tend to suspect a damaged screen. However as Nicky suggested, you should try to do a hard reset (Home & Power Button for 10 secs) of the device to see if that helps. If it doesn't then the next step is to try a replacement screen. Unfortunately, iPad Air 2 replacement screens are very expensive right now. You could bring it into a shop and ask them to see if the screen is the issue. They may charge you a diagnostic fee but that is less expensive than ordering a screen just to find out.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
My Ipad Air 2 had the same problem. It would return to normal after a day of non use. It slowly got worse until the screen would freeze and go black. Given that new info, do you still suspect a bad screen, or is it more likely the logic board? Thanks in advance.
さんによる
コメントを追加
Did you try take a backup and reset the ipad ? i highly doubt this is a screen problem, more like a software problem, also it could be a defect homebutton in the meaning that it will work but if you click it it wil stay clicked giving you everything to see ( siri and so on )
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Khoi Nguyen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 1,003
