メインコンテンツにスキップ
The Kia Sportage is a compact crossover SUV (sport utility vehicle) manufactured by Kia Motors, a South Korean automaker, since 1993. Between 1993 and 2005, the Kia Sportage was classified as a compact SUV.
4回答 すべてを表示
2000 kia sportage no power
acceleration has deteriorated to nothing from a standstill has all new parts just did a new knock sensor..what is causing this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Joann Lastinger we need more information about all of this. First, it'll help if you can tell us exactly which parts you replaced and why. Second, it will help if you even had the OBD scanned to see if it throws any codes. Third, what exact year and engine size is your Kia. With all the replacements you have done, did you get the compression tested or have you performed a leakdown test. The lack of power could be related to a lot of things from fuel delivery to clogged catalytic converter
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Joann Lastinger さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 12
今までの合計 564
