メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
多種多様なカメラの分解および修理ガイド。
How can I remove a totally stripped small camera screw?
Short, and to the point: One of the screws is extremely stripped and I want to remove it. Is there a kit for smaller screws like this, or some way to slot it?
Long: My wife dropped her camera in a pitcher of beer. The camera itself actually still functions, but has problems with the lens cover opening and some gumminess on the controls that in general make it not usable. I already went ahead and bought her a new camera, so now this puppy is mine for the messing with. I thought I'd try to pop it open and give it a good cleaning, but I am stuck on this tiny screw that is totally stripped.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 11
2 件のコメント
if its really small and you dont have a rubber band a slightly thicker piece of paper will do, like from an envelope
さんによる 共有
I scrolled through all these answers and finally found a great answer on youtube. Instead of a pentalobe screwdriver for my stripped MacBook pentalobe screw I used a T2(You can also try T3) and it worked perfectly. If that doesn't work though I recommend drilling out the the screw head with a tiny drill bit at a very slow pace. The screw will be destroyed but works great. https://www.youtube.com/watch?v=TEYgVsPc...
さんによる 共有
コメントを追加
12件の回答
ベストアンサー
I managed to get it out by slotting the screw with a dremel, then using an oversized flathead to VERY SLOWLY screw it out. The screw is completely ruined, but I did get it out! I don't recommend doing it this way, I think the glue would have been a better choice. The dremel cutter was bigger that the screw, and I did do some damage to the camera casing.
By the by, I was actually motivated by your teardown to restart this project! This all happened about 6 months ago, and I first tried to fix the camera but was unable to get this pesky screw out. Thank you for your inspirational (and instructional) article!
If that doesn't work, check out these tips for removing stripped screws:
ネジ山が潰れたネジを取り出す方法
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
you're welcome. and I'm glad to hear you were able to get the screw out. I wouldn't have been brave enough myself to try using a Dremel! :)
さんによる 共有
コメントを追加
最も参考になった回答
If you can find a thin enough one for the tiny screw, the best way to undo a stripped screw is with a rubber band. Just place the rubber band flat over the screw, and it will will in the gaps and provide enough friction to get the screw out.
Cresny
このアンサーは役に立ちましたか?
スコア 8
コメントを追加
I took a flat head screwdriver just slightly larger than the original stripped out phillips slots (original was a PH0), placed it firmly on the head of the screw and rocked it back and forth from corner to corner for a while until it had formed enough of a groove that I could carefully unscrew. I had two very tiny screws with the same issue, one of them I had tried to drill out first with no success, and the other still had vague remnants of the original slots. The drilled out one took longer than the other one for this to work (used a 2.5 for the drilled out one, and a 2.0 for the one that was less stripped).
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Homie, I just made an account to tell you that you just saved my butt. I don't know if you are still active here, but you just prevented me from having to buy another Vive controller. Thank you so much!!
さんによる 共有
コメントを追加
have you tried using a jeweler's screwdriver size smaller than the stuck screw, and firm, slow pressure - as suggested in this article? or the bonding glue idea they also mention?
p.s. the following doesn't answer your specific question, but should you get past the stripped screw, perhaps you may find this teardown of an older model Canon PowerShot camera that I took apart useful as a reference. Good luck with your repair.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You can't possibly know how happy I was to find these tips. The rubber band trick worked GREAT! I sell used watches on ebay and sometimes stumble upon a watch with screws in the back that hold on the back plate. Needless to say, I had 3 expensive watches which all had stripped screws, and no way to get them out. I drilled them out a little first with a small drill bit on the Dremel tool, then the rubber band and a slotted screwdriver and VOILA! I also want to note I had also used a bit of WD-40 to loosed them a little first.
Brilliant ideas and THANK YOU!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I have always enjoyed the hard, yet brittle alloy of an Exacto Blade.
These are small pointed 'razor blade' types available in most hardware and all hobby stores. For small screws, use the blade with about a 15 degree point (pointy) and work the tip into one of the obliterated slots of the former Phillips head screw with a small, firm, slicing motion. The harder alloy will cut the screw's alloy, then break off as you work ;-)
With patience, you'll have worked a slot into the screw head (similar to, yet finer than, the Dremel solution above) And the tip of the Exacto Blade will be just about the right size to use as a screw driver as in the Dremel solution; firm pressure to keep the tip in the slot, and back it out. If it snaps, get a new blade. Beware of loosing patience and making a mess of it(candid personal experience). The wider your new slot is, the better leverage you'll have in turning the screw (radius=lever in this case). If you can get some jewelers diagonal cutters to bite into the screw's periphery on each side, you'll have MAX leverage!
I haven't had to resort to messy oils, but a Liquid Wrench application may help. Also relieve any stresses on the screw (like re-tightening the ones around it) so you are only fighting one thing at a time. Bent sheetmetal parts are notorious for jamming screws; try to flatten them first. Or better yet, turn the sheetmetal to free the screw, if possible! The screw also may have seized due to thermal contraction so warming the area may help (soldering iron-careful yadayada...)
Some products (Japanese) use precision Phillips-type csrews that LOOK like standards, but you should get a good set of Japanese screw drivers if you do this regularly. Search the Humanoid Robot built from Japanese servos, sites for details and sources.
On boats, its not uncommon to use oils, tapping, wait a few DAYS and repeat...several times. In a couple weeks- YOU WIN!
Now THATS persistence!!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
super precise diagonal pliers for fine electronics or circuit board work are also a good idea. If you can precisely bite the top rim of said screw perpendicular to the rim, and jus give it enough turn, she'll at least loosen. You should hear a little click when it breaks itself free. You all know what I mean.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
OH MY GOODNESS. i have soent the past 45 minutes scrolling and scrolling to find things that would work and this saved me from having to buy a brand new phone THANK YOU
さんによる 共有
the soft metal allows the pliers to be able to bite in. Its an old VCR trick taught to me by a former NAVY coworker.
さんによる 共有
コメントを追加
if the camera is a play toy, and the only problem is sticky buttons,
then wash it again, it might need a soak to get the dried residue off.It would have been better it you washed it immediatley to get rid of the beer
Firstly; remove the battery and ensure there is no charge left,and any cards. Then start with warm water and an old tooth brush, the a final rinse with distilled water, leave for many days in a warm place, near the back of the fridge is good.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Another possible solution is to lightly dip a properly sized screwdriver in lapping compound. We've used this to replace stripped screws on aircraft quite a lot. Just be careful not to make a mess... it only takes a dab. If that doesn't work, then we'd bring out the Dremel.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a nintendo 3ds where the child tried to open it up. One screw head is stripped. Would heating the screw head with the tip of conical soldering iron break or loosen the bond with threads and case body? If not is there a small enough EASY-OUT tool to remove the screw???
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I know this is four years later, but that's what I'm trying to do. By any chance did you get it out? If so, how?
さんによる 共有
コメントを追加
I know this is an old thread, but I was searching for a replacement for the small Phillips #000 screwdriver while I was trying to repair my computer. Then I realized I had a solution on my head :)
Since I am a woman, I figured the majority of you guys don't know about this trick, so it could come in handy if you don't have anything else and have around a wife or a daughter.
Just bend to lower part of the clip and you're good to go!
Like this
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have tried every tools in our home, small screwdriver, knife, nail cutter, etc., but these didn’t work. I tried a nipper, the one we use in manicure and pedicure, and it worked like magic! I used it like a plier and voila! The tiny stripped screw was finally unscrewed!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Trying to put a new battery in my computer, that tiny, tiny screw holding the back together stripped very easy and I used the screwdriver they sent with the new battery. I've tried everything I can think of and it's so tiny nothing is working. HELP PLEASE
さんによる 共有
I, too, have the same problem. Any ideas?
さんによる 共有
コメントを追加
回答を追加する
Luke さん、ありがとうございました!
統計データ:
過去 24時間: 25
過去 7 日: 225
過去 30 日: 872
今までの合計 350,479
