メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
2012年6月12日に発売。Turbo Boost付きのインテルプロセッサー、モデル番号は A1278。
1621回答 すべてを表示
Battery not recognized after sata cable replacement
I have a Mid 2012 MacBook Pro in which I recently had to replace the sata cable. I was getting a blank white screen and no hard drive was showing to boot to. I had a colleague of mine, who previously worked at Geek Squad with Best Buy, replace the sata cable for me. When I gave him the laptop, the battery worked fine, the only issue was the hard drive was not showing. After he replaced the cable, the computer booted up fine and everything in regards to the hard drive was working. However, the battery was not showing as active or available.
There is a {X} symbol on the battery when logged in (top right corner) as if it is not connected.
Things I've tried:
- Known good charger (same result)
- New battery (same result)
- SMC reset (I performed the keyboard command but I'm not sure how to tell if it was successful or not)
- The battery indicator on the left side of the laptop does not light up at all
I would like to add that about 2 years ago I did have water spill which affected the firewire port (which I never used), but it still worked after that with no issues for 2 years.
Any help would be greatly appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Try disconnecting the battery indicator; this can interfere with the battery data lines if liquid damaged, preventing the battery from being recognised.
This is unlikely to resolve the issue though I’m afraid. Sounds like your colleague disconnected the battery with a metal tool, or shorted it another way, which can send battery voltage to the SMC through the data line, killing it. Common issue and hear this happen a lot on the forums. Only solution is replacing the logic board or solder a SMC from a donor board.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Matt Surman さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 92
