change laguage back to english
how to get keyboard & langage back to english from japenese
REF: https://www.youtube.com/watch?v=WUFhwe9p...
The above video shows somebody going through the options of changing the language on a Kindle Fire HD. Now, while he goes through the steps while the Kindle is in English, you should be able to press the same options by counting down. For example, he presses the "Language and Keyboard" option in settings. This option is the 9th option down from the top. Then, he taps the first option for "Device Language". From there it should be obvious which is English.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 36
1件のコメント
So I'm guessing you can't read the interface so you can select the right language? You will have to look up which option on the list is the language option and then change it.
Abraham Andres Luna さんによる
