How do I fix my Samsung 46 LED tv that has a picture like the attached
The tv is model UN46EH5300FXZAIt started with the backlights going bad, so I replaced them and now the screen looks like this.
REF: https://elektrotanya.com/samsung_un32eh5...
The above link is the service manual for your TV. First, double check your backlight replacement. Inspect, all cables and connectors between boards. Next, go through the troubleshooting section starting on Page 4-1. I would also pay attention with Calibration (see starting on Page 4-28).
このアンサーは役に立ちましたか?
I tried the link, but it tells me I cant download from other users account. I checked all the connections, and I will look into the calibration section.
Try this link: https://elektrotanya.com/samsung_un32eh5.... Under the image of the manual you will find a line that says "This file is downloadable free of charge:". At first it will say "processing", but give it a couple of minutes and it will change to "Get Manual". Clink on that link and it will download the PDF to your computer.
That worked,thanks!
Still looks the same. I will try and clean the ribbons that connect to the TCom board.
@allanh824 vertical issues are usually not related to the T-con board. Those are most commonly panel (driver/buffer board issues)
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 117
@allanh824 double check your LVDS cables etc. This looks very suspicious of issues with your driver boards, specifically the source drivers. Check the boards where the two ribbon cables from the T-con board plug in to.
oldturkey03 さんによる
