メインコンテンツにスキップ
2017年3月に発売された第5世代iPadのWi-Fiのみのモデルです。9.7インチRetinaディスプレイと64ビットA9プロセッサーを搭載したモデルで、32 GBおよび128 GBのストレージオプションがあります。
83回答 すべてを表示
Home button replacement still wont work after many replacements
The original Home button was destroyed so have bought many screens and home buttons and none work still. Switched a screen and Home button from ipad air 1 , that was working and it does not work either. So thinking there is a procedure to get it to go from a finger print reader to a regular home button. Any thoughts on this or did i miss a memo. I’ve replacement several screens and batteries before and home button tif is in all the way. Any help would be much appreciated. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
You need to use the home button made specifically for the iPad 5th gen which is essentially a replacement iPad 5 home button.
You can't use iPad Air 1 (I have not tried the Air 2 ones which have touch ID but may work) home buttons, I tried doing one this week with it and it did not work.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My 1st 4 replacement digitizers were for ipad 5’s . None of them workedand the air one screen had a replacement home button ordered for a ipad 5 . So NO your conclusion is not right. I’m thinking either something is wrong on the board from the damaged original home button or some other reset needs to be done I’ve seen in a video but forgot to try when the new screen was on. I do have two buttons coming from ifixit and will try one of them. Thanks for your experince in what’s worked for you but as usual everything i get seems to be outside the norm. I’ll wait and see. Just wondering if all the parts I’m getting are just bad ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Perry Green さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 58
