メインコンテンツにスキップ
モデル番号A1708/EMC2978ー2016年10月発売。このエントリーレベルのMacBook Pro にはこれまでと同じファンクションキー(OLEDTouch Barとは反対)が搭載されています。ファンクションキーモデルにはIntl Core i5と2つのThunderbolt 3ポートが付いています。
216回答 すべてを表示
Blackness Creeping Up From The Bottom Of Display
Last year I had to get my display replaced because it completely stopped working. It was under warrenty.
A few months ago a green line appeared at the bottom of te display. After contacting support they told me to reset the NVRAM wich I did. I would come back occasionaly but for the most part it was ok.
Recently it cam back and has been slowly moving up. I can barely see the icons if the doc is at the bottom!
Is this a hardware or software issue?
When I talked with support the first time they said if the NVRAM thing didnt work there would be some setting that could be changed that might fix the issue but I wasn't able to get any more info.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
A solid bar of black horizontally or vertically is a sign the connections have failed along the edge of the LCD panel.
Think how fabric is made woven with threads X and Y. Your display is no different! So if you forget to weave the row or column you get an empty spot.
Here your system had a bang along the bottoms side which had broken the tiny surface wires between LCD panel to the driver logic on the back of the display. Sorry to say you'll need a new display assembly.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
joe.ramirez0 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 94
