I know this is an old post but it was helpful to me, and I want to add some details about what I did…
I don't have CISS but my WF7710 started to have issues after a recent firmware update (wouldn't auto-power off, frequent 10016 errors when scanning).
I wanted to downgrade to older firmware hopefully to fix these issues, but the older Epson firmware update software refused to work, saying I already had newer firmware.
But after more research, I successfully downgraded to older firmware as follows. Note that I have a Mac but I think these steps would be almost the same on Windows:
1. Download older Epson firmware updater software for the WF7710. I found it on one of Epson's support sites.
2. With the WF7110 powered off, hold down the buttons 4, 7, and Job/Status at the same time while pressing the power button. This will power up the WF7710 into recovery mode.
3. Connect the WF7710 to your computer with a USB cable (if not already connected).
4. Run the Epson firmware updater software as normal (since the WF7710 is in recovery mode, the updater won’t complain about newer firmware already being installed).
5. Wait several minutes for the update to finish. When done the screen of the WF7710 should say "Completed" or "Finished" etc. (the firmware updater software said the WF7710 would power off when done but this didn't happen).
6. Unplug the WF7710 power cable, wait a few seconds, connect it again and power it on.
Note that this didn't remove or change any presets etc. I already had set up on the WF7710. But I wouldn't rely on that always being the case with every update.
3 件のコメント
Hi,
It may be quicker to get the definitive information you need, for your model printer, direct from a CISS supplier.
Click on the Ask a question link near the top of the page.
jayeff さんによる
Not really a good solution.
Vladeanu Petru さんによる
I don't have CISS but my WF7710 started to have issues after a recent firmware update. I successfully downgraded to older firmware as follows (I have a Mac but I think these steps would be almost the same on a PC):
2. With the 7110 powered off, hold down the buttons 4, 7, and Job/Status buttons at the same time while pressing the power button. This will power up into recovery mode.
3. Connect the WF7710 to your PC/Mac with a USB cable (if not already connected via USB).
4. Run the firmware updater software.
5. Wait several for the update to finish, you should see "Completed" or "Finished" on the WF7710 screen (the firmware updater software said the WF7710 would power off when done but this didn't happen).
6. Unplug the WF7710 power cable, wait a bit, reconnect it and power on.
Note that this didn't remove or change any custom presets or configurations I already had set up in the WF7710 but I wouldn't rely on that always being the case.
Alex B さんによる
