メインコンテンツにスキップ
Repair and disassembly guides for GE Microwave ovens.
349回答 すべてを表示
The power level won't power down to 50% (to melt) but stays at 100%
The power level won't power down to melt or use 50 % for some frozen dinners. It only stays on "high" 100%. thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
So when you press the Power Level button does the display not change? Typically what you want to do is select the amount of time you want to cook, then press the Power Level button until it display 7 or 6 or 5 or whatever you want, then press Start. With older microwaves you often would hear the microwave generator power off and on throughout the cycle, with newer ones they seem to just run at a lower intensity without any noticeable change in pitch or speed.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Yes, Cook Time first, then Power level. When it worked, we could press 45 seconds at power 6 and melt butter, now it splatters within 15 seconds.
さんによる
Yes, Cook Time first, then Power level. SEEMS STUPID THAT YOU HAVE TO USE THIS SEQUENCE-ONLY-. Of course there are many stupid things GE (NOT USA) does. So...SET TIME COOK FIRST, even if it is dumb.
さんによる
コメントを追加
回答を追加する
Michelle さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 21
今までの合計 3,903
