iPad screen 'ghost touching' even worse after attempted repair
My iPad would sometimes sporadically ghost touch the screen during use. After searching I tried following the advice on Digitizer activating itself after digitiser replacement. Unfortunately it seemed to make things worse with the screen now very frequently ghost touching. I also must have not put the home button back on correctly as it won't click when pressed like normal. I put Kapton tape on the edges of the digitizer and then replaced the adhesive pads. I didn't remove the LCD panel so a small part of one of the adhesive pads had to go over the cable connecting the digitizer to the LCD but it didn't look like that would cause an issue. Did I put too much tape on? Is there something else I should have been watching for that could cause worse ghosting? Thanks for the help!
この質問は役に立ちましたか?
1件のコメント
I have bought several ipads that have had a new digitiser installed and each time it was the ribbon that had a break in it...the plastic is very brittle and is only safe to be bent once or twice....it must be under the LCD not on top where it will be pressed into a tight bend when the digitiser is laid on it....sometimes the break is hard to see but using another digitiser solved it every time..people are buying cheap digitisers and doing it themselves....cheap ones are cheap for a reason....bend only once or twice
lynne.denman さんによる
