How Do I add Ram to Dell laptop Latitude 505?
How do I add Ram to a Dell Latitude 505?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Look at your documentation or go to the Dell support web site to find the correct memory type and speed if the information isn't in the service manual here.
Then:
1 Shut down the computer, disconnect the power cable and remove the battery.
2 Remove all the external components and cables from the computer.
3 Close the display screen and turn the computer base-side-up.
4 Locate the square-shaped memory module compartment in the middle of the base. Extract the screw from the memory module compartment cover and take the cover off the computer. The Dell Latitude D505 may be equipped with two memory modules, and the upgrade will have a better effect on the system if paired memory is installed as opposed to a single module.
5 Spread the clips on the sides of an existing memory module and the module pops up at an accessible angle.
6 Pull the module straight out of its connector.
7 Insert a new module into the connector at an angle. Press the module down until the clips lock into the notches on each side of the module.
8 Repeat steps five to seven to install a second memory module.
9 Replace the memory module compartment cover and secure it to the computer with the screw.
このアンサーは役に立ちましたか?
Looks good except step 2 I think should be remove battery.
Good looking out. I thought I had that in there, thank you.
+ cab - check your link, it may be broken
A quick way to find out what memory you have on your laptop is to use this website http://www.crucial.com/ click on the install scanner link and the scan will tell you how much and what type of memory your laptop has, it will also tell you what the maximum memory your laptop can take.
You are allowed to have your link in your profile putting it in answers is spam.
このアンサーは役に立ちましたか?
Hi,
I would suggest you before you actually open up your laptop RAM cover to install additional ram you tube to look for tutorial. when you turn your laptop upside down you will see a mark for RAM module open the screws and plug in the RAM in extension slot and close the lid.
Good Luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,969
