メインコンテンツにスキップ
Repair information for KitchenAid dishwashers.
19回答 すべてを表示
Rinse only cycle works, but not any wash cycles
I replaced the food chopper, because it was worn out. Cleared debris from that sump area, both screens, large and small particulate, and cleaned out spray arms, top and bottom. Ran a Rinse-only cycle to test, results: Pan filled with water, quite rapidly, spray arms sprayed water, water drained at end of the cycle. All looked normal.
Ran a Wash cycle next, to test, but water did not fill dishwasher. Made a grinding noise, as if no water, so I cancelled the cycle, nothing to drain.
Next, turned off circuit breaker for at least one minute. Ran Rinse-only cycle: No issues.
Ran 1-hour wash cycle: Didn't fill with water again. Cancelled.
Ran Heavy-duty cycle: Didn't fill with with water, AGAIN.
Why does it fill, spin, and drain on Rinse-only cycle, but NONE of the Wash Cycles seem to work, even after shutting off power at the circuit breaker several times?
HELP!!! About to give up on this one, though I seem like I'm so close.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
What is your specific brand and model number?
さんによる
KitchenAid model: KUDC10IXWH7
さんによる
KDTE704DSS0 KitchenAid Dishwasher
さんによる
コメントを追加
2件の回答
ベストアンサー
I fix Appliances for a living and sound like a bad water valve to me. Or stuck float switch, it could even have a crazy water tank setup thing on the side of the unit causing issues, test for power at the water valve or simply hold the magnet/valve when it should be onand you should feel it vibrating. Otherwise, the control boards “water relay” could be worn and either replace that component or the board. When they dry wash it tears them up. Over revs, friction on the chopper, added heat, the element could sorta over heat..
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks Levi, I'll give those testing options a try, and let you know.
さんによる
コメントを追加
20OCT18. I also had this same issue. I first replaced the mother board, thinking it fills first time all the time… then fixed itto replace the water valve.
What is happening ? The valve is getting hot and it takes too much current to make it energize and stops filling. The computer board was okay.
To verify this: Turn on your washer with the sanitize setting. let it run for about 5 minutes then cancel it and rerun it again. Mine failed, retried several times… wait an hour and it fills. then ig will not work. — this was repeatable. I wasted money on a computer board where it was the valve due to a poor design that is effecting lots of people …
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
ThreeClarks さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 35
過去 30 日: 161
今までの合計 13,204
