Pioneer avh 290bt, won't go past loading screen.
I have a Pioneer avh 290bt installed in my 06 Nissan 350z. It turns on but just continues loading.
Does anyone know how to fix this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @chrissyj ,
Try resetting the microprocessor and check if this resolves the problem.
With the ignition switched OFF press the Reset button for a moment or two, with a pointed instrument such as a pen tip.
See the image below to find out where the Reset button is.
(click on image to enlarge for better viewing)
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 28
過去 30 日: 139
今までの合計 13,873
3 件のコメント
I have a avh 4200 nex with the same problem, i wont pass the loading screem and keeps rebooting, this happen after i replace my battery terminals
lazaro morales さんによる
Mine is a pioneer touch screen without buttons… it is also stuck on loading screen. I tried battery disconnect for 2 minutes but still same. It has no buttons just the touch screen icons that are on side but not actual buttons therfore I can not “reset" can someone help
Ky Tha don さんによる
I have the same issue with my dmh-160bt n nothing works Evan tried in a different vehicle n nothing it's 4 months old n it's now a dash ornament so I'm out $275.00 n pioneer does not warranty there stuff
Jason Hoover さんによる
