メインコンテンツにスキップ
Cuisinart Griddler GR-4N a five-in-one kitchen appliance to be used as a contact grill, panini press, full grill, full griddle or half griddle .
How do I replace the coil and the wires leading to the coil?
Hello, one my upper heating coil, one of the wires leading from the power to the coil has rusted and fallen away from the coil, so it doesn't heat. Is there a replacement wire assembly for this, and how do I open the griddler to detach and then reattach the new wiring to the griddler so that it will heat up again?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Hi Karen,
do you have the solution for that?
I have the same problem.
さんによる
コメントを追加
1 件の回答
Karen - all the wires are steel WELDED in place,,, thats the rusting problem.
To repair, remove all rust from the burned post. A small raspy file is used. Skin the insulation back to rust free wire and wind 1-full-coil around the post. Now comes the difficult part.
It must be silver-soldered, or brazed, which requires a flame. I cannot explain the how-tos in this small box.
Do not attempt tape, sooper-glues, or try-this-stuff. These GeorgeFormanFryers can knock you down !
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Karen Wolfe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 223
