メインコンテンツにスキップ
The Toyota Yaris is a subcompact car produced by Toyota since 1999. Between 1999 and 2005, some markets received the same vehicles under the Toyota Echo name. Toyota has used the "Yaris" and "Echo" names on the export version of several different Japanese-market models.
25回答 すべてを表示
Air or heat not blowing through vents
When I turn on the knob for air/heat nothing blows through vents. What could be the problem and how much could it cost to repair it? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
First off get your car scanned, if you live in the States. Some auto places do it for free.
Check your fuses, and relays. On the fuse box it should tell you what fuse is what. Also the hand book should tell you if you have it.
If fuses and relays are good. It could be a faulty switch.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kimberley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 207
