PSP won't turn on without AC; and it will shut down short after
Can you diagnose for me what this means? Video link below
Hi @intagaming ,
The first thing to try is to replace the battery.
Failing batteries can give unusual symptoms.
Start with a known good battery and then check if there are any other problems.
Alternatively measure the voltage of the battery and check what it is as opposed to what is should be as stated on the battery itself. (do this out of circuit)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 38
今までの合計 426
