Tilting screen causes image to turn negative (Video)
Hi there ifixits!
I have a problem with my MacBook screen. Sometimes when I tilt it or wear it on my lap so that the screen moves ever so slightly the screen image turns negative and flickers quite a lot.
The problem does not present itself when connecting an external monitor through the Mini DisplayPort. I also took a peek inside to see if any wires had come loose, which they hadn't. I did however only take away the lower case so it's quite possible I was not able to see all wiring.
(image) http://db.tt/fA4dSoD (normal, duh)
(image) http://db.tt/KzhJya2 (negative)
(video) http://www.youtube.com/watch?v=t-cpACFnQ...
(It's not Ctrl-Alt-Cmd-8 even though it may look similar.)
Hopefully I've provided enough information, if not, let me know!
この質問は役に立ちましたか?
1件のコメント
HELP! Screen Color is Negative! (Not Ctrl-Alt/Opt-Apl-8)
mayer さんによる
