The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
mike vernon @mikevernon
評価: 1
投稿日: 2018年4月23日
My car has an oil leak. It also blows back oil through the dip stick
この質問は役に立ちましたか?
tcagle53 @professorc
評価: 8.2千
Professor C's E-repair and Upgrade Service
24
12
8
Sounds like your PCV valve needs replacing.
このアンサーは役に立ちましたか?
oldturkey03 @oldturkey03
評価: 778.1千
1.1千
890
2.3千
mike vernon possibly blown piston rings. Check or replace your PCV valve as suggested and then do a leak down test. It will tell you a bit more about what is going on with your Camry
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 52
