メインコンテンツにスキップ
Device repair and troubleshooting guides for the HP Pavilion 13-s128nr x360, a consumer 2-in-1 laptop by HP released in September 2015.
21回答 すべてを表示
How to fix "plugged in, not charging" in HP Pavilion 13-s128nr x360?
When the AC adapter is plugged in, it is shown "plugged in, not charging" and the battery light indicator does not come on. How could this issue be fixed?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
It sounds like the charger is not sourcing enough current to the laptop. Are you using the charger that came with the laptop, or an aftermarket charger/charger for another HP laptop?
さんによる
コメントを追加
3件の回答
a few different things can cause the error youre getting.
1) Make sure the full voltage is coming from your AC Adapter. :::: Adapter may need to be replaced.
2) Make sure your Port is accepting a Charge :::: Port may need to be replaced
3) make sure your battery is accepting the charge from your adapter. (proper voltage at the pins while charging) :::: This is usually a logic board failure.
4) Make sure your battery is good. (replacing it is the most simple way to do this.)
If any of the above is failing, fix accordingly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i’m having the same problem, it happened after I used a 12v to 120v converter in a car, it makes a buzzing noise and something might be fried, it works if I unplug and plug it in like 1000000000 times
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i'm buying a new plug to see if that's the problem
ps. I'm using a HP pavilion notebook from 2016
さんによる
コメントを追加
Did you upgrade to windows 10? I seems this is a driver issue with the battery controller. im still researching it but the charging works under Windows 8.1. Once you go to 10, it's over. Microsofts battery driver overrides the original HP driver and doesn't enable charging while plugged in.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jasmindubellay0784 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 12
今までの合計 5,275
