メインコンテンツにスキップ
Why won't my computer turn on when plugged in w/battery in or out?
I tried turning my computer on while plugged in, but nothing no power indicator or anything. I removed the battery and tried turning it (still plugged in) and still nothing. I did forget my laptop in the trunk of my car for a couple of days, and I am concerned if it was affected by moisture.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Soooo many reasons could cause this, and the only way to be sure is to run a full diagnostic on it.
you could have a problem with your AC adapter.
you could have a problem with your power button
you could have an issue with the charger port,
you could have an issue with moisture
you could have an issue with board damage
I would try testing for each of those, in that order, to find out what you need to replace.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Daniel V さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 91
