メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
1437回答 すべてを表示
Why does my ps4 turn off after I turn it on?
My ps4 randomly turned off and had no reason to. I tried to get back on it on it didn't. it was checking the storage and beeped then the light turned red and shut off. I tried it the next morning and I got it to work. It was rebuilding the database and I think it finished. Right after that, the light went red and it said the overheating message and instantly turned off. I don't know whats wrong.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
This indicates your PS4 has overheated. This could be narrowed down to a number of problems.
Fan failure
Hardware failure
Possible bad motherboard connection to the fan
Immense dust collection inside the PS4
Blocked vents.
Sony advises to send it in after this type of error. Though if you want to save money, you can find a fix on here. Remember when fixing to take your time.
Hope this helped fix your error.
このアンサーは役に立ちましたか?
スコア 1
コメント:
Note: Opening up your PS4 will VOID VOID VOID VOID VOID your warranty, though I find warranty unfair.
さんによる
Personally I use a GPU reflow machine for the APU chip on the logic board to fix these PS4s with overheating issue after confirming that the power supply is not at fault, in this case for OP they know it's overheating issue.
Cheap fix is washer but funnily enough I've seen some PS4s last 3 years even with just the washer trick.
さんによる
I just found out that my brother got are dad to buy a new one. Thanks for your help and I will keep your help in mind.
さんによる
No problem. Happy to help! Try what people suggested to see if you can get your old one back up and running.
さんによる
I will thanks
さんによる
コメントを追加
There may be something wrong with your fans and hard drive. Clear your vents, and try again.
このアンサーは役に立ちましたか?
スコア 0
コメント:
Also true. ^^^^
さんによる
コメントを追加
回答を追加する
O22y 86 the gamer さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 246
