メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HX9360 can't turn on
I measure the battery about 3.8V.(F1 /R6 point).So I think the battery is fine.
But I push the button can't turn on it.But put into the cup can charge the battery.
So how do I to check the board or more action?
thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I have probably a similar issue. Who can find and change a battery here?
さんによる
コメントを追加
2件の回答
最も参考になった回答
swat1230 your voltage maybe fine but it is not a good indication of your battery being okay. It is possible that your battery simply does not hold enough charge to supply the demand. I'd start with a new battery first, then re-evaluate. Check your switch circuitry etc. with your multimeter.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I'm having the same problem. Have you fixed it?
Thanks!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I have also checked the switch circuitry, which is fine. Additionally I have also connected an external power supply with 3.8V. Unfortunately it didn't helped.
さんによる
I have exactly the same issues, battery power is still good. Have so. fixed the problem yet?
さんによる
コメントを追加
回答を追加する
swat1230 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 18
今までの合計 2,623
