メインコンテンツにスキップ
2017年Appleは13インチMacBook Airに新Broadwell Intl Core i5プロセッサを搭載して登場させました。バッテリー寿命の改善とパフォーマンスがわずかに向上しました。
422回答 すべてを表示
Which sensor is closest to the Battery?
I'm trying to monitor battery temperature over time. But I can't see it in the XRG 2.5
But from the available sensors, which one really could best indicate the temperature of the battery? In other words, which one is physically located closest to the battery?
I'm using MacBook Air (December 2017)
Recommendation for iStats alternative with Battery Temperature Graph
Is there a way I can see a graph of the battery temperature? I could do that from iStats Menu. Now I have to resort to XRG which doesn't really have 'Battery Temperature' :'(
I need to see the graph FROM MENU BAR. Not a persistent widget blocking my awesome wallpaper.
Update (04/18/2018)
I used another 3rd party tool to compare and concluded the following correlations:
Bottom Sensor #0 ~ Battery Sensor Max
Bottom Sensor #1 ~ Batter Sensor 1
Bottom Sensor #2 ~ Battery Sensor 2
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
How about accessing the batteries own thermal sensor? I would use CoconutBattery to see it:
If you want to monitor it over time I would use TG Pro's built in logging function and then import it into a spreadsheet. You'll need the full version to do it.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Incredible! Thanks for recommending this awesome app. However, my pupose here is to monitor battery temp over time to make sure the coolpad and room fan setting made a difference :
さんによる
コメントを追加
回答を追加する
Devansh Trivedi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 116
