メインコンテンツにスキップ
HPによるインクジェットプリンター、スキャナー、コピー機能が全て搭載されたデバイスです。モデル番号はCX042A。
Why is it printing so small? Can't read the documents.
When I print a document it comes out extremely small. What needs to be adjusted
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 17
2 件のコメント
When in your Browser:
Got to the upper right side and go to the three horizontal marks (The Menu).
Go down the list and select Print.
Go over to the scale and if it is not on 100%, then change it to 100%
さんによる
it is set at 100% and still prints very tiny
さんによる
コメントを追加
4件の回答
最も参考になった回答
What program are you printing from? When the printer dialog box opens, what scale do you have it at? Does it print small for all document types (e.g. html, word document, pdf, etc.), or on only certain documents?
For example, if printing from Chrome, click on the "+More Settings" and see what the Scale is set at. If not set at 100, change it to be so. If printing from Adobe, set the "Page Sizing & Handling" to "Fit" - stay away from "Custom Scale". If MS Word, in the "Zoom" section, set "Scale to paper size" to "No Scaling".
Each program that you try to print from, typically has an option to adjust the scale of printing. Make sure it is set to 100%, or fit to page, or no scaling. If your scaling is correct, then you need to check your Printing Preferences.
To do this in Windows 10, go to your Printers & Scanners menu in Settings. You can click on search and just type "printers" and it should bring up the option. Click on your printer and select "Manage". Then, click on the "Printing preferences" link, this will open up the Printer Preferences dialog box. Click on the "Effects" tab, and make sure the "Actual size" option is selected. Also, go to the "Paper/Quality" and make sure Paper size is set to the proper paper size (Letter 8.5x11 inches is most likely what you want). Then, click OK/Apply.
If this doesn't work, then you may need to reinstall or upgrade the driver from your printer. You can download it from here: https://support.hp.com/us-en/drivers/sel...
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
There is no "Effects" option on my HP printer. What is the other option?
さんによる
when printing from my laptop the samsung xpress sl 2070m printer prints have the size of the original , whereas it prints normal when I print the same file from my mobile phone , I dont know why , may be because I recently reinstalled the drivers of my printer.
さんによる
コメントを追加
When printing from your Browser, go into your browser, look in the top right upper corner and right click on the three horizontal bars (Menu for your browser). The go down and select Printer. Go towards the right and see what the Scale is set on. If it is not on 100%, then change it to 100%, Maureen Carven.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
its not the printer its the emails I am receiving all small for some reason help
さんによる
コメントを追加
It’s small and unreadable
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Allow normal size to complete legal paperwork
さんによる
コメントを追加
I'm sorry to hear that your printouts are coming out small and hard to read. There could be a few reasons why this is happening. One possibility is that your printer's settings are set to print at a smaller size. You should check your printer settings and make sure it's set to print at the size you need. Another possibility is that the document you are trying to print is set to a smaller size or has a low resolution. Make sure the resolution of the document is set to at least 300 DPI for clear and readable prints.On a different note, have you ever heard of Persian tattoo's? They are beautiful and intricate designs that are inspired by Persian calligraphy and art. They are a great way to add a personal touch to your body art and create a unique design that is both meaningful and visually stunning. I always try to create something new, and Persian calligraphy is an amazing way to create truly stunning tattoos.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Maureen Carven さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 38
過去 30 日: 133
今までの合計 72,921
