Any way to check for long screw damage?
Hi!
I have in my hands an iPhone that I suspect has either long screw damage or a bad chestnut chip (that might have gotten too much heat in the past).
The thing is I would rather not remove the crew hole for nothing in case it is not the cause of my no image/backlight problem.
Is there any way to check it before cracking it open?
Thanks!
EDIT: Photos of the actual screw hole
EDIT 2: Took out the screw hole, there are some delamination but not too much
Btw sorry for the quality of the screen! ;D
EDIT 3: Scraped the top layer and it ended up really well! Straight away I can see broken likes (I think I broke 2 of them, but that should be easy to fix).
この質問は役に立ちましたか?
