My R4 sdhc gold pro 2016 isnt loading on 2ds 11.6
I was putting some games on my R4 gold and then I put it in my game card slot, and it's not showing no matter what I do, help!
Did you remove Ntrboot from your card? Did you download right R4 Gold kernel?
このアンサーは役に立ちましたか?
Umm I did and its all correct its something wrong with the card like its not reading
hi. Do you have the Gold Card or the Gold PLUS like this one https://www.r43ds.org/products/R4i-Gold-... as that one has a switch inside that lets you go between using it in DS mode and using it for NTRboot. If it is the older version, which backup.bin are you trying to use?
このアンサーは役に立ちましたか?
I have SDHC gold pro 2016 and I'm using the correct backup.bin and I opened mine up and there's no switch
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 1,542
Look, the most logical thing to say would be, did something go wrong when installing the game? (Is it compatible, does the R4 Gold work with the 2DS, etc), check for the most logical causes.
Also did the problem start to occur AFTER you installed the games or before that already?
Lena Fox さんによる
You could try using this: http://www.instructables.com/id/Toturial...
This might help to make it work again.
Lena Fox さんによる
its that my R4 card isnt reading and i need help
Matthew Pinto さんによる
