How to replace rear view mirror?
How does the rear view mirror changed? It does not stay up (Onstar).
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
評価: 13
The interior rear view mirror on many American cars is mounted to a small piece of metal that is glued to the inside of the windshield. If your mirror has fallen down, and there is not a piece of metal stuck to the glass, the piece of metal is still most likely mounted to the mirror. Usually loosening a screw on the underside of the base of the mirror will release it.
To reattach the mirror, go to your local auto parts store and buy a rear view mirror adhesive kit. These are generally around ten dollars, and consist of a cleaner and a tube of adhesive. Don't try to use regular glues or superglue. Follow the directions on the back of the package to glue the metal piece in place. Make sure you orient it correctly on the glass, and wait the recommended amount of time before hanging the mirror up again.
I hope this answers your question. Good luck.
コメント:
+ very clear answer
mayer さんによる
+ good concise answer.
oldturkey03 さんによる
My problem is, where the mirror is glued to on the windshield. Is right in the middle of the textured sunscreen pattern, the only way I can prep the glass. Is to grind a spot and removing sunscreen and the old glue from the glass . . .
puentes7 さんによる
過去 24時間: 3
過去 7 日: 6
過去 30 日: 12
今までの合計 5,148
Which rear view mirror? There are more than 1.
ABCellars さんによる
I believe this is referring to the center rear-view mirror that is inside the vehicle as opposed to the side-view mirrors outside the vehicle.
Matt Barnes さんによる
