Bad USB causing my battery to short?
I have a 2011 MacBook Pro .. It has been working fine no problems .. until the other day .. I came out to use it and it would turn on was off . battery completely dead even though it was plugging into the charger .. I changed battery then it worked fine .. so tonight it happened again after just changing the battery .. I was changing my iPad in a usb port using a cord that i think was plugged in before when this happened . Can a bad USB cord effect the battery ..
so this last time .. I took off the back .. disconnected the battery and replugged it in .. and it work ..
so just trying to trouble shoot?
1件のコメント
Could you explain in more detail what you are having problems with cause I do not understand this situation.
Bomber_Bot さんによる
