メインコンテンツにスキップ
The Golf Mk5 was introduced in Europe in the autumn of 2003, reaching the UK market in early 2004. In North America, Volkswagen brought back the Rabbit nameplate when it introduced the vehicle in 2006.
28回答 すべてを表示
My RPM is crazy high
Hi i just bought myself a 2007 Volkswagen Golf city 2.0 5 speed manual and well first thing i noticed was my RPM was insanely high for example i would be driving at 120km/h 75mph and my rpm would be at 4000 in fifh! Anyways i was wondering if there anything i can do to bring down my rpm or if the car is just made like that
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
The 5 speed manual transmission on the Golf 5 has a pretty close gear ratio which means the rpm's are pretty high at higher speeds. What engine do you have in your car (Diesel or Petrol, how many KW?)?
Do you only have the seemingly high rpm's when accelerating or also when cruising? If you would only have the problem when accelerating then it could also be a slipping clutch.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
4000 RPM'S is not good on your engine if it was an automatic I would be concerned about it not shifting gears as a manual I wonder if your transmission is actually shifting as it should
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have this issue but my car is automatic and at 80 it’s rpms are at 4000!!! Help me,
It’s a 2003 Volkswagen gls 2.0 automatic it was fine until today. I flushed all the fluid and put new stuff in. Do you think we put the wrong stuff in I asked the guy at the store and he said he was 100% sure but like I can’t afford to fix this cars transmission
さんによる
コメントを追加
I own a 1999 Cabrio GLS 2.0 auto and it’s always had the high RPM’s at cruising speeds since it was new. It’s simply geared low to provide for quick acceleration. So it’s completely normal.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Patrick Carrière élève さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 25
今までの合計 2,313
