メインコンテンツにスキップ
The Sony Ericsson Xperia X10 Mini E10i runs on a custom version of Android and features 3G access. Released in 2010.
33回答 すべてを表示
締切られた回答
The Micro-USB is not firm enough, do I need to replace it?
Hi,
How can I improve the USB cable connection since it does not seem to be firm enough...
How hard is it to replace the Micro-USB connector? is it welded or just fit?
Where can I buy this component with confidence?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It is definitely soldered onto the main board, and you would need a fine soldering tip as it has 5 contacts really close from each other. If you are able to use your usb, then you just need to apply some solder on the usb bases, which need 4 blobs of solder on each corner (which makes it sturdy). If you wish to replace it then you would need to solder 5 contacts plus the additional 4 blobs for sturdiness.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
If all 5 pins are soldered and none of the solder joints are broken, how is adding more solder going to make it more secure and/or solve the problem? I can understand adding solder to any broken solder joints.
さんによる
Read my comment once again. Solder on usb corners (not saying it's the same on every case) tends to break. I understand you know what a solder joint is. Good for you. but I mean adding solder or just reheat the current solder on the four corners in this particular case. One more time; there are 5 pins on this usb plus the 4 corners that make the usb connector a lot stronger.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,996
