メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
iPhone 6+ won't turn on
I have an iPhone 6 plus that was working fine. I gave it to my cousin after I replace the screen and days later the new screen stopped responding. The only way it would respond to touch is if she would press on the screen very hard. Her friend ended up pressing on the screen very hard to the point it cracked. Then phone would turn on again after that but the touch was unresponsive. Later on, she slammed it on her bed and it turned off completely. It hasn't turned on since.
iTunes does not recognize it at all. I've replace the battery, the charging port and the screen and still no response. The motherboard however does get warm when plugged into the computer. What can be done? Any suggestions? Please and thank you!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
If you've tried a new screen, battery and charge port, pretty much the only thing left is the logic board. It could be a damaged connector or there could be a dislodged component in the connector area. If you want to, you should take a close look at the logic board, preferably with magnification to see if there is anything obvious.
Otherwise, you should have this looked at by a micro-solderer.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Nilsa Rodriguez さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 27
今までの合計 641
