Why is it beeeping
The beep code is 1-1-1-1-1-1 th en turns off I've tried removing all the parts and I had a cpu that was the same one I switched th e cpus and still beeps. I know it's not the ram cause I just got the ram 2 days ago. I haven't taken out the cemos yet I'll try that but if anyone knows how to fix I need the awnser.
この質問は役に立ちましたか?
4 件のコメント
@mcofficalplays what make and model is your computer? What motherboard is it? Did it have this issue before you replace the memory? Have you tried the old memory
oldturkey03 さんによる
@mcofficalplays
list out the make and model as mentioned from oldturkey03
check on your graphic card and power supply also.
Augustine さんによる
My computer is the Brodcast pix slate g 1000 i tryed removing the graphics card and I got this without ram but,with the ram type
McOfficialPlayYT さんによる
@mcofficalplays try opening up the casing, take pictures of inside mainboard, perhaps install a working graphic card and see if it boots up
Augustine さんによる
